5
Discussion topic: Soundbox Connection
This message was authored by Sara+T This message was authored by: Sara+T
Soundbox Connection
Hi,
I have just been given a Soundbox but the optical input on my tv is broken. Can I connect any other way? I'm not really tech savvy 😟
This message was authored by mike+simmonds This message was authored by: mike+simmonds Answer
Re: Soundbox Connection
Hi @Sara+T
if you are just using the Soundbox for just your Sky Q box - you can manage without the optical part of it
so put an HDMI cable out of your Sky box and IN to your Soundbox (the black socket in the middle )
Then another HDMI cable OUT of your Soundbox (the pink socket) and IN to your TV
That will let you listen to what your Sky box is playing
Without the optical cable - what you can't do - is listen to the output from the TV itself - or from other connected devices - like dvd players etc
(the reason is that the Soundbox doesn't have something you would need - called an ARC socket - which allows audio to travel both ways in to the same HDMI socket )
hope that helps
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Hi @Sara+T
hope that helps
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by Mock+King+Jay This message was authored by: Mock+King+Jay
Hi Sarah
If you have Two good HDMI cables, you can connect a box/blu-ray player etc into the Soundbox, then out of the Soundbox to your TV. If Soundbox does not think your cables are good enough, no signal. Just switch the ouput to "HDMI," the nice lady says.
If your TV has Bluetooth output, you can connect it to your Soundbox this way.
Sara+T
Oh wow thank you so much for that. Will try Bluetooth 😊
Bluetooth is a good suggestion from @Mock+King+Jay  if your optical port is broken. I recall in the forums a while ago - a few people using Bluetooth were noticing an audio lag (where the sound and vision were not happening at the same time)
if you experience this - on the soundbox remote you have an audio sync button (followed by plus or minus)  which you can use to try to synchronise sound and vision.
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by SwanieBoySenior This message was authored by: SwanieBoySenior
Works a treat! Thanks Mike
On average, new discussions are replied to by our users within 5 hours
