Discussion topic: Phone does not ring on incoming calls
Message posted on 17 Mar 2025 01:24 PM
I am a brand new customer for broadband and telephone. My phone was fine under BT but now it doesn't ring on incoming calls.
Message posted on 17 Mar 2025 01:26 PM
Re: Phone does not ring on incoming calls
Is your phone plugged into your broadband Hub? Are you able to make calls?
Message posted on 17 Mar 2025 01:35 PM
Yes I can make calls without any problems. All 4 lights on the hub are green.
Message posted on 17 Mar 2025 01:38 PM
How 'brand new'? It can take 24 hours for all Sky Talk services to be working as they should.
Message posted on 17 Mar 2025 01:40 PM
Thanks for the reply. Today is the first day so I'll give it 24 hours and then check it again.
Message posted on 17 Mar 2025 01:49 PM
It is now working, so all good.
