7
This discussion topic has been answered Discussion topic: stuck on sky intro
This message was authored by: TimS7
stuck on sky intro
My sky HD+ box is stuck on 998 Sky Intro. I have changed the batteries and taken the plug out numerous times. Sometimes I get a different screen. For example, the sky intro video played on a loop. I can change inputs but changing to HDMI 2 (Prime etc) and back to HDMI 1 makes no difference. Any ideas gratefully received.
This message was authored by: Annie+UK Answer
Re: stuck on sky intro
You may have move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
What happens if you press the ch+/- buttons on the top of the box?
Avatar for TimS7
Nothing, I'm afraid. There's no change.
Pull the Sky boxes plug from the mains for at least 5 miutes then plug it in again
If that fails try Q04 (Software update) in my Sky Plus FAQ, though this should not be any better than the above
Avatar for TimS7
Thanks, but I have tried this many times. Nothing changes.
Avatar for TimS7
Thank you, I was beginning to think the same thing.
Avatar for TimS7
Annie+ UK, I took up your suggestion of moving to Sky Q as nothing else seemed to work. Thanks for taking the time to suggest ideas - much appreciated.
