Discussion topic: part rec technical fault -7(33) shows on every recording on my SKY+ and breaks up on re watching
Message posted on 29 Oct 2024 05:02 PM
when watching the reording back it keeps stoppong, showing, recording interupted by loss of signal press back up to return . The sky planner shows part rec technical fault -7(33) shows on every recording on my SKY+ planner
Message posted on 29 Oct 2024 05:05 PM
Re: part rec technical fault -7(33) shows on every recording on my SKY+ and breaks up on re watchin
Message posted on 04 Nov 2024 11:30 AM
this hasn't worked,
If I am watching live while also recoring the same programme there arent any signal issues & it's perfect & interuption free however if i watch that same proramme back it continually breaks up.
downloaded recordings playback perfectly & so does recorded radio programmes, but every thing else is part recorded technical fault that consistantly breaks every few minutes showing Part rec; technical fault - 7 (33) interuptred please back up to resume recording
Message posted on 04 Nov 2024 11:35 AM - last edited: 04 Nov 2024 11:36 AM
Technical fault 7 generally indicates a problem with your hard disk. You could try a full System Reset (same menu as a Planner Rebuild) which might resolve it, possibly only temporarily. You'll lose all your recordings by doing it, I'm afraid. Failing that, it would be best to speak to Sky to see what alternative upgrade options you have.
