Discussion topic: I cannot turn my TV on as the blue light on the SKY box is going round continuously
This message was authored by: Jonkan
I was watching a recorded programme and the tv just turned itself off. The blue light on the SKY BOX IS ON CONTINUOUSLY
Re: I cannot turn my TV on as the blue light on the SKY box is going round continuously
Do you have a Sky Plus box?
There could have been a power spike
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Have you tried restarting your Sky box by switching off at the plug for 4 minutes?
@Jonkan  If this is a Blue Circle on the front of your Sky box then you have Sky Q not Sky +
Does your box look like this?
Avatar for Jonkan
Great idea it worked   Thank you
