Discussion topic: no sky
This message was authored by: kennethdugan161
no sky
having issues with sky saying there is none
Re: no sky
@kennethdugan161  What is the excact nessage you're seeing?   If it's No Satellite signal then as Sky+ is no longer supported you'll need to get an independent installer to check your dish.
Re: no sky
All Sky can tell you is there are no issues with DSat broadcasts😉
What sort of issues are you having ... you are responsible for your reception equipment🤔
Re: no sky
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
