Discussion topic: losing channels
This message was authored by: baz1662
losing channels
I have good signal and quality strength on my sky setup menu but have suddenly lost a lot of channels was advised could be the lnb so have replaced the lnb and still the same problem channels didnt pixelate or go funny they just disappeard
Re: losing channels
Do you have a Sky+HD box or an older standard definition Sky box?
Avatar for baz1662
Re: losing channels
older style box but i have the same problem on another non sky hd box
Re: losing channels
Do you have a Sky+HD box?
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
Avatar for baz1662
Re: losing channels
no its an older box but I am having the same problems on another box which is a hd box
Re: losing channels
See question Q48 in my Sky Plus F⋅A⋅Q
Avatar for baz1662
Re: losing channels
checked out your q48  i understand that I cannot rx ch5 hd on my old box but that does not explain why I have lost channels as I can get ch5 hd and other hd channels on my other box? Aand both boxes are working of my quad lnb
Re: losing channels
If you read my FAQ then that says the some SD channels sometime in August 2024 will not be accessible unless you have a HD box
Have you tried turning OFF your HD box at the mains for at least 5 minutes?
Performing a software update of the HD box can sometimes force the channel list to refresh
Avatar for baz1662
Re: losing channels
Done all that going to get a second had sky hd box and see if prolem still persists if so just have to bite the bullet and get a satellite installer to have a look to see if there is any other problem thanks for the help
