Discussion topic: Wireless networking
This message was authored by: FishBowl
Wireless networking
WiFi will not connect on Sky plus box. If I press the WPS button I get message, 'problem with the wireless networking device'
Re: Wireless networking
Have you tried rebooting your router and Sky box?
Avatar for FishBowl
Yes, many times. I think the issue may be that when the WPS button on the Sky box is pressed, no led comes on and I get the error message above.
Try setting the wifi up manually
Avatar for FishBowl
Option not now available on screen. Contacted Sky and looks like box has had its day. Sky Q on its way.
 Thanks.
