Discussion topic: Will wall connection be correct?
This message was authored by: sessa
I am renovating a house that will need rewiring - they are going to put a double co axial socket and a single Cat 6 socket/connection where I intend to put the tv etc -  will the double co axial be the connection(s) Ill need for plugging in my Sky HD box?They'll run the cable to the attic & leave it there for when dish is set up.
Is there something else I should be asking for or setting up in advance?
Thank you
Re: Will wall connection be correct?
Why are you not asking the people who will be doing the job?
You should be telling the exactly what is needed!
@sessa
A Sky engineer won't go up into the loft/attic if that's what you're implying.
@sessa wrote:
...will the double co axial be the connection(s) Ill need for plugging in my Sky HD box?They'll run the cable to the attic & leave it there for when dish is set up.
For the dish connections? No. You need satellite connections - see the image.  But as noted, a Sky engineer won't go into the loft to connect the cables to your dish. You may need an independent satellite installer to do it for you.
