3
This discussion topic has been answered Discussion topic: No signal for input 2 on sky hd box (i live in a house)
This message was authored by: Bounty123
Hi i have no signal for input 2 on my sky+ hd box. (Input 1 is fine)
i only have channels for today up until midnight tonight. I have no listings showing for tomorrow and the rest of the week and I can only record on a daily basis. This issue has been going on for about a week now. The weather has been fine so that's not the issue.
i have tried switching everything on and off a few times, as well as changing the cables but to no avail.
Any help greatly appreciated, thank you.
This message was authored by: Mark39 Answer
Re: No signal for input 2 on sky hd box (i live in a house)
It looks from your post as though you've done all you can do, and the next step is to book an engineer who will locate and fix the fault.
In the meantime, you can set your Sky box to Single Feed Mode to restore your TV listings but obviously you'll still only be able to record one programme at a time. The setting is in the Installer Menu which you access by keying Services,0,0,1,Select on your remote.
Avatar for Bounty123
Thank you Mark39, your suggestion has enabled the listings, i've also phoned sky who have told me the problem is with my hd box..... it's very old.
@Bounty123 wrote:
....i've also phoned sky who have told me the problem is with my hd box..... it's very old.
It's possible, but hard to see how they can even hazard a guess, without a visit to check Sounds like a reprehensible ruse to get you to upgrade to Sky Q. If you don't want to, you don't have to, regardless of what the adviser may have told you.
