14
This discussion topic has been answered Discussion topic: Viewing card won't pair
This message was authored by: wildcard2142
I pair the card using the box and it says request successful. Your channels will be available shortly but nothing changes
This message was authored by: Annie+UK Answer
Re: Viewing card won't pair
@wildcard2142 wrote:
I have a multiroom  and a main card, I have cancelled the multiroom card which ends this month, but this box is better than my main box so want to pair to that one, my main card was damaged so asked for a new one to be sent out to me
You CANNOT do what you want, as of end October 2024 the card is LOCKED to the box it was in as that time and CANNOT be transfered into a different box
Your main box card replacement can only be used in your MAIN box and NOT you multiscreen box
@wildcard2142
Is this the same Sky+ box the card was paired to at the end on October 2024?
Was this card paired to this box at the end of October 2024? As the card now gets locked to the box it was paired to at that time
Avatar for wildcard2142
No its a new one and I have cancelled the card that's in that box, that runs out at the end of the month, maybe it will work when that has ended
@wildcard2142
It will no longer pair to a new/different box I'm afraid. You can't now pair a viewing card to another Sky+ box. Sky Customer Services are available to provide advice and troubleshooting. Sky+, being a legacy package, is no longer supported by Sky.
Still call Sky to discuss your options moving forward which will be upgrading to Sky Q or moving to Glass / Steam to continue to view Sky content through a Sky subscription.
You CANNOT pair any card to a new box
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
The technical Team just said they can repair or once this one has ended?
@wildcard2142
If this is a different box to the one it was paired to at the end of October you CAN'T.
Its a brand new card and not been paired to a box
If Sky have sent you a replacement card then Sky should be able to pair it remotely, but only if this is the same box the non-working card was in
This is quite confusing as to the reasson for needing to pair the card 😞
Why all the capitals? The main card hasn't been in a box for over a year so isnt linked to a box and shows on the sky app its not linked to a box it just says self install, the other card is showing the HD box
This message was authored by: MERC1950
Pair my viewing card on my sky go
Sky Go is software and does not require a viewing card
