Discussion topic: Tv not working properly
This message was authored by Deirdre+o+meara This message was authored by: Deirdre+o+meara
The picture and sound is flickering in and off.  This is happening for weeks sick of paying for no service.  I tried to phone and got nowhere
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Tv not working properly
Check the HDMI cable between the Sky box and the TV
Signal Strengths/Qualities? Take a look at the link below:
Question Q11 in my Sky+ FAQ
Annie  ( Please Note: I am Neurodivergent - ASD )
Deirdre+o+meara
Checked and No problem
Try a Planner rebuild:
For Sky Plus HD boxes (DRX890/DRX895) with the latest software try the following instructions:
• Press SERVICES on your Sky remote control
• Go to Help
• Select Sky+ Rebuild
• Press SELECT (this will start the rebuild)
If the above does not work try the following (Note: the first 5 steps are better done whilst looking at the remote control as the feedback on screen can be confusing):
• Press 0 (very old boxes may need you to press 4 instead)
• Press 0
• Press 1
• Press SELECT (You should now be in the hidden menu)
• Press 7 (Sky+ Rebuild)
• Press SELECT (An on-screen message will be displayed)
The above and so much more can be found in my Sky Plus FAQ
Deirdre+o+meara
Still not working
@Deirdre+o+meara  If after follwing @Annie+UK   guide it still has not been fixed the it may well be the box at issue.
You have 2 options, call Sky who may provide a refurbished box (although they may push you towards Sky Q), or purchase a second hand box online.
As SkyHD boxes stopped being made over 6 years ago you will struggle to find a new unused box.
This message was authored by Mark39 This message was authored by: Mark39
How did you check the HDMI cable?
Deirdre+o+meara
I could not get through to sky
On average, new discussions are replied to by our users within 100 minutes
