4
This discussion topic has been answered Discussion topic: Technical fault on recordings
This message was authored by: Man+u
When playing back a recorded programme the error message" there is a technical fault with this channel please try again later,"
I have tried later as suggested, makes no difference
This message was authored by: Mark39 Answer
Re: Technical fault on recordings
This message was authored by: AmritdeepBhatti
Problem with re cording .trying to watch all programs says Technical issues
Try a Planner Rebuild. If that doesn't resolve it tell us exactly what the error message says.
This message was authored by: jason712
I can record a programme but I cannot download them for instance when it says restart the programme , it fails every time . The technical fault - 11 (272)
