Discussion topic: Technical fault on channel
This message was authored by: andym1968
Sky tv not working
tgere is a technical fault with this channel, please try again later.
the message is on every channel
Re: Technical fault on channel
@andym1968 What are your Signal Strengths in Services > Settings > Signal Strengths.
All four white bars should be at least half way across.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
