This discussion topic has been answered Discussion topic: TV interference from mobile phone
Message posted on 07 Jun 2024 07:26 AM
Hope somebody can help.
I have a Sky hd box that I have 4 tvs running off it. The 3 tvs that have magic eyes continually get interference from any mobile phone signals in the house. I've tightened all the connections on the sky box and wall socket and also made sure all the connections to the aerial sockets are also tight. However this has made no difference. The crackling sound appears to be getting worse especially when the phone rings or there are incoming emails and messages.
best regards
steve
Message posted on 07 Jun 2024 08:17 AM
The frequencies assigned for use by cellular devices has expanded to include those formerly used by tv channels 50 to 68.
By default the RF channel used by your Sky box to distribute the analogue signal to your 3 TVs is set to 68, which consequently now makes it liable to interference from mobiles etc. Change your Sky box's RF Output Channel to a channel below 50 to avoid the interference. You'll need to retune the 3 TVs once you've done so.
Message posted on 07 Jun 2024 08:50 AM
Re: TV interference from mobile phone
Mark
Thank you so much for your help. This has fixed the problem.
outstanding help
best regards
Steve
Message posted on 03 Sep 2025 01:39 PM
I've been trying to solve this for nearly a year and finally stumbled on this answer and it's worked !! Thank you Sooooo much !!!!!
