Discussion topic: Some Chanels say box not getting signal
This message was authored by: Deanna3
Picture on all chanels started breaking up, like it does in bad weather, and some chanels were saying box not getting signal.
As our box is over 15 years old, we have swapped it for a new one.
Now several chanels are working ok, but 105 to 112 and 901 are still showing box not getting signal.
The movie chanels said we needed to pair card with box, which we have done and they are ok. But the 105 to 112 and 901 still have box nit getting signal
Re: Some Chanels say box not getting signal
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Deanna3
Thanks Annie
I think may be we will have to get an egineer.
The dish has been in the same place for 22 years. The box had been working with it for 15 years. The new box is the same type as the old one, so it may be the dish lnb as you suggest.
Thank you
Deanna
Sky will not now offer an engineer booking for Sky+ / Sky+ HD unless you have pre-existing Sky Protect cover at the address: this is part of the processes of running down the remnants of the Sky+ platform.
If you don't have Sky Protect covering the equipment, you'll need to contact (and pay) a local independent installer: Sky will just tell you to move to Sky Q, which realistically couldn't happen until the new year.
