Discussion topic: I’m waiting for someone to ring me back and they haven’t.
This message was authored by: TheKillone
Both of my sky televisions have gone down and it says no satellite signal. I rang yesterday and was told someone would get in touch by the end of the day but that didn't happen and then I rang back today however someone disconnected me. Urgent action is required as I'm trying to run a business.
Re: I’m waiting for someone to ring me back and they haven’t.
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@TheKillone
Am I missing something here. What has no satellite signal on a Sky+ box have to do with running a business?
@Daniel0210 wrote:
@TheKillone
@TheKillone in addition to the above sky subscription services are for domestic use only and therefore sky has no obligation to you in relation to your business unless you have the necessary sky business account
For a business television subscription you should have a dedicated contact point outside of normal domestic support.
