Discussion topic: SkyHD box card pairing
This message was authored by: Mike571
I have tried many times to pair my viewing card using the services menu on my SkyHD box without success..
where can I telephone to get the card paired
Re: SkyHD box card pairing
@Mike571  Is this a replacement Sky+HD box?  If so you can no longer pair your card to another box.
@Mike571
So basically Sky+, being a legacy package, is no longer supported by Sky.
If it applies to you, you can't pair a viewing card to any other Sky+ / Sky+HD box that it wasn't paired to at the end of October 2024.
You can still call Sky to discuss your options which will be upgrading to Sky Q or moving to Glass / Steam to continue to view Sky content through a Sky subscription.
Why do you need to do that?
Avatar for Mike571
I have changed my Sky box..
since my post I have spoken to Sky and they are sending me a new card for my SkyHD box..
@Mike571
I doubt that will happen to be honest.
The viewing card will be locked to your old box as cards for the past 12 months are not transferable between boxes
Unless Sky have changed their policy (unlikely) it won't work, for the reasons @Annie+UK posted.
Did you tell Sky that it was a different box?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
