Discussion topic: Sky viewing card not working
This message was authored by: neillondon
My sky is giving me the message saying " This viewing card is not authorised, if you have received a new veiwing card please insert"
I have the old sky box but cannot get sky Q as I live in a flat and doesn't work.
can someone help please??
urgent!
Re: Sky viewing card not working
@neillondon  If you ordered Q this would set an automatic process off to cancel existing viewing cards
if you have subsequently cancelled the order you should have still received a new viewing card if so use this replacement card
if you haven't received a new card call sky to request one
If you order Sky Q and it is cancelled for any reason the Sky+ viewing card gets disabled and cannot be re-enabled, you then need Sky to send a replacement card
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for neillondon
Level 0 icon
Thankyou for your help
