Discussion topic: Sky remote not selecting
This message was authored by: CLEOPATRAEndee
Hi I need help please my sky remote will turn on the tv but won't select anything I can't move left or right and it won't select
Re: Sky remote not selecting
Is this a new remote or has it worked OK before?
Avatar for CLEOPATRAEndee
It has worked before had it for 6months now and all of a sudden today both remotes on both tv's
I assume both TVs are connected to the same Sky+ box? Try turning off your Sky box at the plug for at least 4 minutes, then check the remotes again.
