Discussion topic: Sky+ HD box connected to communal dish.
This message was authored by: TR47
I had to disconnect my sky box from the satellite feed when I had carpet replaced. Plugged it all back in the same and input 2 now doesn't receive a signal and the Lock Indicator says Not Locked. I now can't record 3 things at once.
Any suggestions please???
Re: Sky+ HD box connected to communal dish.
Check the centre pin/wire is not bent or the fine shield wires are not touching the centre pin/wire
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for TR47
Thanks for replying. I was super careful when I replaced the cables and even bought a new one in case that helped. Sadly not 🙄
You'll need to contact the people who maintain your dish (landlord/buildings management)
Avatar for TR47
Ok. Thank you. I'll get onto that 👍
