Discussion topic: Sky +hd volume
This message was authored by: Stephen087
Sky +hd volume
When I change the volume I am disconnected from the Chanel in watching
Re: Sky +hd volume
Can you clarify what you mean by disconnected?
Avatar for Stephen087
Re: Sky +hd volume
Disconnected is not a clear indication.
when the volume changes the program I'm viewing cuts out  ( black screen )
sky box unresponsive for 15 - 20 seconds. Sometimes longer requiring a power off.
I hope this gives you more information
Re: Sky +hd volume
@Stephen087 it does, but it's not something I've come across before. Does the same thing happen if you use the TV remote rather than the Sky remote to change volume?
Re: Sky +hd volume
Hi Mark
in addition to the sky remote ( which was replaced a week or so ) I have the Logitech remote which causes the same problem. The tv is a Panasonic with the tv speakers disabled as I have a Bose solo 5 speaker for sound.
I forced a reload this morning to see if that may help with no effect.
thanks
Stephen
Re: Sky +hd volume
Try turning OFF HDMI Control in the Sky Plus Settings, it might be conflicting with your TV
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
Re: Sky +hd volume
Mark
turning HDMI control off seems to make no difference
Stephen
Re: Sky +hd volume
Odd. It appears the IR signal for changing the volume upsets your Sky box. Is your remote programmed to control your TV volume or your Bose volume or both? Or does your  TV control the Bose volume?
Re: Sky +hd volume
Hi Mark
the tv speakers are disabled, the only sound is through the Bose speaker
Stephen
