Discussion topic: Sky+hd remote codes jvc tv
This message was authored by: Phartymick
HELP!!! I have just got my new jvc tv that suggests 4 codes to programme your sky remote, none worked. I contacted sky, their 8 didn't work either. I can only get 2060 to turn the set off, not on or do the volume, I'm pulling my hair out. Does anyone know if jvc are using other brand named codes like vestel, I tried them too. Sky have unfairly taken off the "pair your remote" option off the sky+ hd box since I last did it this way working perfectly, why remove something that works? Gggggrrrrrr
Re: Sky+hd remote codes jvc tv
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Phartymick
Thank you, I will give it a try after I've eaten my meal x
