Discussion topic: Not all channels getting signal
This message was authored by: SA161
Some of the channels are not working saying sky box isn't getting satellite signal
Re: Not all channels getting signal
Reboot your Sky box and/or check the cables
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
