Discussion topic: Sky+ epg nothing beyond midnight
This message was authored by: annoyedofhampshir
No epg beyond midnight, no series like possible, cannot record beyond the end of today, pretty useless really, I do not have wired Internet so no way to catch up either, tried all the reboot/press button things I've seen multiple times and I do mean multiple. Help please
Re: Sky+ epg nothing beyond midnight
Hi @annoyedofhampshir
@annoyedofhampshir
You've posted on the Sky Q board but your thread title refers to Sky+ so can you confirm which you have?
Avatar for annoyedofhampshir
No EPG beyond midnight today
No epg beyond midnight, no series link possible, cannot record beyond the end of today as I can't see it to select, pretty useless really, I do not have wired Internet so no way to catch up either, tried all the reboot/press button things I've seen multiple times and I do mean multiple. Help please
Apologies my poor 4G kept chucking me out and I ended up in the wrong group, sorry Sky+ question
Re: No EPG beyond midnight today
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
That's indicative of an absence of a signal from the dish on one of your dish cables. Check by going to Services > Sett8ngs > Signal. The white part of all four bars should be at least half way across.
set single LNB (LNB1) both bars near 100%
I don't know what that setting is, but it doesn't sound like the right one. If you have only a single cable from the dish you need to set Single Feed Mode on.
yes in single feed mode with the feed on LNB (feed) 1
@annoyedofhampshir  Is thinking happening on all channels or certain ones
if certain channels only which ones are affected
All channels whether subscription or not
Odd. The only circumstances where I've come across this before are where there are two dish cables and no signal from the dish on one of them. I don't suppose the dish has been disturbed recently?
