6
This discussion topic has been answered Discussion topic: Sky dish
This message was authored by: Tj777
Sky dish
Hi there
is it possible to get a contact phone number to speak with an agent ? I want to make an enquiry about getting an old sky dish that is no longer in use removed from my roof as it's come loose and is dangerous , thank you .
This message was authored by: Annie+UK Answer
Re: Sky dish
Customers own the dish so it is down to you to employ a third party, Sky DO NOT provide dish removal services especially for the obsolete Sky+ systems
Re: Sky dish
Re: Sky dish
@Tj777
And therefore the householder is responsible for any injury or damage caused in the meantime, especially as you've disclosed in a public forum you consider it dangerous. I'd arrange to have it removed asap which will be at your own expense.
This message was authored by: SoulboyScotland
Re: Sky dish
can someone confirm that I should remove uninstall dish myself? As part of moving to Stream I specifically asked the question and the Sales told me Sky would remove the dish - was this just Sales talk? thx
Re: Sky dish
@SoulboyScotland  As postd above Sky do not remove dishes it is your responsibility
Re: Sky dish
It's your dish, do with it as you see fit
Sky don't support Sky+ with "engineers" any more
Re: Sky dish
Unfortunately, yes.
