Discussion topic: Viewing card
This message was authored by: Carriec9
Viewing card
My sky box is just saying that my viewing card is not authorised and I can't access any programs
Re: Viewing card
If Sky have sent you a new card then perform a New Install with that card
If you have ordered Sky Q and the order has not gone ahead for any reason the Sky+ card will have been cancelled and you'll need to use a new one, if you don't have a replacement then you'll need to get Sky to send one
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Carriec9
Level 0 icon
Re: Viewing card
I don't have a new card and I haven't ordered a new card so why has this happened?
Re: Viewing card
No clue, try a New Install with the current card to do a callback to Sky, if that fails to fix it then you'll need to phone Sky
You can contact Sky using the number here (See the "Need more help?" dropdown near the bottom of the page)
Note: Make sure you have the correct country flag selected in the bottom-right of the page
