310
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky catchup unusable
Locked
This message was authored by: Geering1993
Re: Sky catchup unusable
Very frustrating for everyone!
Do Sky have an email I can contact them on? Hopefully, if enough people complain, they will look into it properly
This message was authored by: GeoffH
@Geering1993 wrote:
Referring back to the answer Annie+Uk has given, how do i find the unique IP address for the box? Do I need that, or just change the other part to 1.1.1.1 / 1.0.0.1? Thanks
If you Sky box was previously using DHCP then you are best off leaving it like that and changing the DNS setting in your router's configuration/admin panel. If you don't know what you are doing with manual configuration then you could make things worse, or invite problems in the future if other devices on your network are using DHCP and your router assigns the address you manually configured for your Sky box. If you don't understand what I mean, or how DHCP works or DHCP address ranges you are better off leaving everything on your network configured to use DHCP and hope that Sky and/or their content delivery network and/or our ISPs sort the underlying problem out.
I see some customers on the Sky Q board suffering a similar issue have followed the advice provided by @Annie+UK on this thread and it's apparently resolved it for them.
This message was authored by: Kayelaina
@Daniel0210  seems maybe not @GeoffH  has just advised that it worked for him last night but now the issue has returned and he is unable to download again.  Including BBC which was not an issue before.
Networking is more of a mystical art than a science 🙂 Good to know others are finding the info helpful
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Thanks Geoff.
I don't feel confident enough to change things right now so will be patient and see if it gets resolved. Thanks a lot for your help though
This message was authored by: Patski
All your answers are brilliant, but to anyone who doesn't have a clue regarding the Sky network setup, they are overwhelming.  I'm close to backing down, ringing Sky and getting them out here to do what they have to do whether it be fixing or replacing.  I don't have a smart TV either but everything worked fine previously.
@Patski
Sky won't send an engineer for any Sky+ issue. It hasn't been supported for over a year now.
@Geering1993  you can email them on viewerR@sky.uk
Avatar for Jaskate
Level 3 icon
This message was authored by: Jaskate
I just checked again after changing DNS yesterday on router and still all ok, tried BBC, UK Gold, U and Paramount Plus all ok no lag or failures
Thank you. I will do that now.
@Kayelaina
I did say some and apparently.
This message was authored by: nanokem
I just spoke to someone in the technical department.  They said there were a lot of other users experiencing difficulties and they're escalating the problem.  They advised us to wait for them to provide a solution, but I'm not holding my breath.
My jealousy knows no bounds......😄
That's good news. Thanks for the update 🙂
Locked
Answered - Go to Answer
