Discussion topic: Sky box
This message was authored by: Gary.+N
Sky box
Sky + box turned of and flashing red
Re: Sky box
Power LED? That suggests a fault in the box's power supply circuitry. The box will need replacing I'm afraid.
Avatar for Gary.+N
Re: Sky box
Can't find red reset button it says behind my sky panel at front   Where is that
Re: Sky box
Sky+ does not have a red reset button
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Gary.+N
Re: Sky box
Thankyou so no way of resetting box
Re: Sky box
Not from what looks like a hardware failure
Avatar for Gary.+N
Re: Sky box
Box just suddenly turn off. Tried rebooting and power button on remote. Box just intermittently red light comes on for couple secs then goes off. Any suggestions. Thanks
Re: Sky box
@Gary.+N
The youngest Sky+ HD box is eight years old (they ceased manufacture in 2015) so irretrievable hardware failure is always a distinct possibility.  Sky will advise you to move to Q: if you do not wish to do so, last model units are £20 to £30 on eBay.
Re: Sky box
The only possible reset with your box in that condition is a front panel reset. But I doubt it will do anything given that it looks like hardware failure. If you want to try it for your own peace of mind:
- switch off at the plug and then press and hold the left and right buttons on the front panel, (not the remote)
- switch back on keeping the buttons pressed and wait until LED cirle flashes
- when it does, press Select on the front panel and the LED circle will rotate backwards
When it stops your box has reset.
Failing that, replace the box, or switch to Sky Q or Sky Stream.
