11
This discussion topic has been answered Discussion topic: Sky + box not working
This message was authored by: Rj39
I have plugged in a new sky box and swapped the viewing card over but it isn't working
Re: Sky + box not working
@Rj39
You can no longer pair your viewing card with a replacement Sky box (since the end of October). Sky+, being a legacy package, is no longer supported by Sky.
Still call Sky to discuss your options moving forward which will be upgrading to Sky Q or moving to Glass / Steam to continue to view Sky content through a Sky subscription.
@Rj39
Avatar for Rj39
Thanks. I have now switched the boxes back and it still isn't working!!
In what way is it not working? What error message are you seeing?
Avatar for Rj39
It says no signal yet everything is connected  properly.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
@Rj39 that's nothing to do with the Viewing Card, then.
If it's 'no signal'  there's a problem with the HDMI connection between your Sky box and TV.
If it's 'no satellite signal' it's a problem with your dish, as @Annie+UK explains in a lot more detail.
Avatar for Rj39
Thanks All
I have plugged everything back in the same place as before so really confusing
as you say it's not a viewing card issue.
This message was authored by: Vivienne2025
The remote control is not communicating with the box
@Vivienne2025 restart your Sky box by switching off at the plug for at least 4 minutes.
This message was authored by: Jodieford
The box I have is the size of a coaster very small but no card to be put into it and this does not work we have to push the wires in to get a picture on the tv so actually could be the wires 1 x wire for tv and the other wire with plug could someone tell me how to fix this problem please
This is the forum for Sky Plus box issues, it sounds like you have Sky Stream that has its own forum
