Discussion topic: Sky box not responding
This message was authored by: Dancav
Hi
sky box has stopped working downstairs . It says it's not receiving a signal but the skybox upstairs using the same satellite is working fine . It is quite old now so suspect the box has given up .
Re: Sky box not responding
@Dancav not necessarily. Your box downstairs uses different cables and a different connection at the dish.
Try restarting it by turning the box off at the plug for 4 minutes. While it's off, check that the dish connections at the back are still securely fitted.
Check the cables from the dish
Unscrew input 1 & 2 then swap them over and screw them back in, finger tight
This message was authored by: JoanWilliams
The box is back on , but no green
Thank you all good now ,up and running.
