3
This discussion topic has been answered Discussion topic: Sky+HD box doesn't recognise connection to router after a power cut
This message was authored by: RP61
Since a bulb blew elsewhere in the house and tripped the main fuse, the sky+ box hasn't recognised the physical connection to the router. I've changed the cable , plugged it into different ports, "rebuilt" the box, rebooted it but there's still nothing. The Network page just shows "connection to router: FAIL", "Connection to On Demand: FAIL", "IP Address of box: 0.0.0.0", "DHCP: ON"
I don't get the option to connect to wifi manually even if the cable is disconnected.
Is this terminal?
This message was authored by: GD1 Answer
Re: Sky+HD box doesn't recognise connection to router after a power cut
@RP61  Have you tried the following steps in this order?
Turn off the Sky+HD box at the wall, then fully reboot your broadband hub, once rebooted then power the Sky+HD box back up.
You may then need to reset the network within the Sky+ menus.
Avatar for RP61
GD1 - many thanks. That worked!
For future reference, how do you reset the network within the Sky+ menus?
Thanks again
Thanks again
@RP61
Press services on your remote then Settings > Network > red button.
