Discussion topic: Sky box not recording
This message was authored by: AndrewJones2
My sky box has stopped recording programs and no longer series links
Re: Sky box not recording
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@AndrewJones2 if a Planner Rebuild doesn't help, you may have a problem with the signal from your satellite dish on one of the two cables. Check by keying Services > Settings > Signal on your remote. The white part of all four bars must be at least half way across.
