Discussion topic: Sky+ box issue
This message was authored by: bernie1965
Sky+ box issue
Our Sky box doesn't record /hold programs anymore
Re: Sky+ box issue
Can you play existing recordings back? What happens when you try to record? Does the programme you select to record show as Failed in your Planner? If so, highlight a Failed recording, and press the i button on your remote. The failure reason will be shown on screen - what does it show?
Re: Sky+ box issue
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
