Discussion topic: Sky + box N/W
Message posted on 05 Mar 2025 04:33 PM
Sky + box N/W
Continuous message saying 'box still initializing, please try later' I've since found out the hard drive is likely goosed, spoke to Sky who don't do Sky + anymore and offered me Sky stream at exorbitant rates, my area is not engineered for Sky Q, any suggestions would be appreciated. Regards Graham.
Message posted on 05 Mar 2025 04:40 PM
Re: Sky + box N/W
There isn't much more we can suggest, if you don't want Sky Q then Sky Stream is your only other option, either that or if you are not in any contract with Sky that you cancel to go elsewhere.
Message posted on 05 Mar 2025 04:41 PM
Re: Sky + box N/W
To stay with Sky you'll need to subscribe to Glass or Stream if Sky Q is definitely not an option but research both throughly first.
Message posted on 05 Mar 2025 04:44 PM
Re: Sky + box N/W
A constant initialising message is associated with a problem with the signal from your dish, not the hard drive. The box can't initialise without a signal.
Not sure what Sky mean by your area not being engineered for Sky Q - unless you live in a flat, perhaps? A dish that can receive a Sky+ compatible signal can receive a Sky Q compatible signal too, after the LNB on the arm has been changed.
Message posted on 05 Mar 2025 04:58 PM
Re: Sky + box N/W
We're still getting all the channels although not pause/rewind, so one would assume the signal is OK.
- We do live in a flat served by a communal dish ( approx 100 outlets) when we decided to go for Sky Q, they arranged for an engineer to visit who, on arrival told us the terrace wasn't engineered for it. ! !
Message posted on 05 Mar 2025 05:02 PM
Re: Sky + box N/W
You're limited to Sky Stream then, unfortunately.
