2
This discussion topic has been answered Discussion topic: Sky+HD not working
This message was authored by: Chris3875
Sky+HD not working
Internet working fine. Sky+ box showing a green light, just nothing on the screen! Tried the usual turning the whole thing off and on again, nothing still.
This message was authored by: Annie+UK Answer
Re: Sky+HD not working
Sky+ does not need broadband to work, it used the dish
Check the cables etc...
Try a forced software update, though this is really just a fancy reboot these days
If the screen is completely blank, check that you are on the correct HDMI source and check the HDMI cable is securely connected at both ends.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
