Discussion topic: No signal
This message was authored by: sheila71
No signal
Got no signal
Re: No signal
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: No signal
@sheila71
No signal or no satellite signal? They are different.
If it's no satellite signal then I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
▪️I AM NOT A SKY EMPLOYEE ▪️
