3
This discussion topic has been answered Discussion topic: Sky HD box no sound on HD programs
This message was authored by: hectory
I have a Sky + box, my problem is that for the last week I am unable to get any sound from any HD programs, all the SD programs are ok, I'm only using the box for free view programs and dont have a subscription, any help will be appreciated.
This message was authored by: Annie+UK Answer
Re: Sky HD box no sound on HD programs
Check the audio setting is set to NORMAL and not DOLBY D
Avatar for hectory
Level 2 icon
@Annie+UK Thank you so much, this worked, I cant understand why it should have reverted to Dolby as it was working up until a couple of weeks ago, thanks again, great forum this.
Yes very strange as the Sky+ boxes no longer get software updates, but glad you're sorted now 🙂
