Discussion topic: Hi how to you get a smart tv to work with a magic eye
This message was authored by Portermag This message was authored by: Portermag
Hi I've just upgrade my bedroom tv to a smart tv and can't get my magic eye to tune into it. It works fine with the old tv
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Hi how to you get a smart tv to work with a magic eye
If the new TV does not have an analogue tuner then you cannot use the same setup as your old TV
I am Neurodivergent Sky+HD  LG NanoCell TV  Xbox SeriesX
My F•A•Qs: Sky GlassSky StreamSky GoSky Plus
As @Annie+UK indicates, new televisions can be expected to have an onboard digital tuner for digital Freeview.  The output from the RF socket on a Sky+ box is analogue: in fact it's about the last analogue 'source' left, which is why television manufacturers don't cater for it.
Portermag
Ok thank you sounds like I'll just have to run a hdmi cable in then 😱😢
Make sure you don't make the HDMI run too long as there is a limit to the length without extra hardware
You should be able to get ten metres, given you're only worried about HD rather than UHD, and possibly further.  Round HDMI goes round corners better.
You'll also need to consider how you are going to do non-line-of-sight remote control.
On average, new discussions are replied to by our users within 100 minutes
