Discussion topic: Signal keeps fading since storm box said engineer req
This message was authored by: Andy393
Signal faded
Re: Signal keeps fading since storm box said engineer req
Is this a Sky+ box? What exactly is the error message?
Avatar for Andy393
Sky +
Keeps fading
Then last message was call engineer
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Andy393 wrote:
Sky +
Keeps fading
Don't recognise that as a Sky+ error message.
