Discussion topic: Search facility sky +
This message was authored by: JohnCrooks
The search facility is not working on sky plus I've tried rebooting that didn't work
Re: Search facility sky +
@JohnCrooks
Is the internet connection working on the box, you can check this via services (on the remote) > services > network.
Avatar for JohnCrooks
internet connection is fine
Give a planner rebuild a try:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something. Your recordings and downloads are safe when doing this.
No difference at all
@JohnCrooks What happens when you try to Search?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
just goes on to the programme list, this is getting annowing time to rethink my subscription i think
