Discussion topic: Satellite signal
This message was authored by: Louisemitchell
Satellite signal
My neighbours have erected scaffolding which is blocking my dish. Consequently I have no satellite signal
Re: Satellite signal
Sky no longer provide engineer support for Sky+ systems, so you would need to engage a local satellite engineer to relocate the dish for you.
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass, Sky Stream and Sky Q (Satellite TV is approaching end of life so is not a long term solution)
Get your neighbours to relocate your dish temporarily then reposition it when the work is completed, this is not a Sky issue, if they will not help then you'll need to arrange this yourself with a local satellite installer or wait for the work to be completed
We had the same situation and had to sort it ourselves 😞
