Discussion topic: Can’t get sky+hd to work after move
Message posted on 12 Jun 2025 09:30 AM
Moved from old address to new address, sky + had working fine at old address. When I connected my box to Satellite sockets at new address ( which had sky Q and worked, with 2 feeds) message on sky+hd box says sky box not getting a satellite signal! I have checked all connectivity and all sound, what can I do?
Message posted on 12 Jun 2025 09:35 AM
Re: Can’t get sky+hd to work after move
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Message posted on 12 Jun 2025 10:23 AM
@Chris1954 wrote:Moved from old address to new address, sky + had working fine at old address. When I connected my box to Satellite sockets at new address ( which had sky Q and worked, with 2 feeds) message on sky+hd box says sky box not getting a satellite signal! I have checked all connectivity and all sound, what can I do?
If you know that the previous occupants had Sky Q then your Sky+HD Box won't work. The LNB on the dish isn't compatible with your box. You would need to employ a local satellite company to get it changed. Or switch to Sky Q yourselves.
This is assuming that you have your own dish rather than a communal system.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 12 Jun 2025 10:59 AM
@Chris1954 might be a convenient time to consider upgrading to Sky Q?
