Discussion topic: Sky+ box stopped receiving signal and is permanently initialising
This message was authored by: Gareth116
My sky+box is only used for free channels. Via a satellite. It has been working perfectly but today I turned the box off at the mains and now it says it is not receiving a signal and is permanently trying to initialise. Please advise
Re: Sky+ box stopped receiving signal and is permanently initialising
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
