Discussion topic: Remote not working
This message was authored by: Kendilou
Remote not working
I am unable to use my remote. It will not let me turn the channels over, it flicks off the tv guide, will not let me choose a channel.
I have replaced the batteries and turned it off by the plug
Re: Remote not working
Does the LED light up on the box when you press a remote button?
This message was authored by: Tommy2
have you tried cleaning the remote ? especially where the sensor is that transmits the signal. Also it might be worth gently clenaing the buttons as sometimes they can become stuck and covered in dirt. Finally is the LED light comming on at all ? if none of this works then you may need to buy a replacement remote.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
