Discussion topic: REWIND TV CHANNEL
This message was authored by: Madcatwoman17
REWIND TV CHANNEL
Hi
I cannot watch this channel as the picture is pixelated, the recordings fail and the settings says no signal. All other channels are fine. Any ideas, please?
Re: REWIND TV CHANNEL
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
@Madcatwoman17 wrote:
Hi
Are all other channels definitely working or are you having the same problem with any of these?
164 - Blaze
355 - Now 70s
356 - Now 80s
665 - Gems TV
If those channels are also not working it sounds like a dish alignment fault and you will need to arrange an engineer visit. As noted above Sky no longer support Sky+ and will suggest you move to Sky Q unlesss you have Sky Protect insurance.
Avatar for Madcatwoman17
Hi,
None of those channels are working either. I DO have Sky protect, so I'll contact them.
Thank you for your help 😁
