Discussion topic: No signal
This message was authored by: Irene52
No signal
My tv is showing no signal
Re: No signal
No signal? Or no satellite signal?
They're not the same.
Re: No signal
@Irene52
If it's no satellite signal then it suggests it's almost certainly a dish misalignment or an issue with the LNB (the arm on the dish). Sky no longer support Sky+ and Sky+HD, but if you have Sky Protect through Domestic and General Insurance you can call them to arrange an engineer, otherwise you'll need to employ a local satellite engineer at your own expense to check it (or contact Sky to upgrade to Sky Q or change to Glass / Stream).
Re: No signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
