292
This discussion topic has been answered Discussion topic: Sky catchup unusable
This message was authored by: Geering1993
Re: Sky catchup unusable
Oh right. How did you read it?
I just reread it and see what you mean. I'm gonna just leave it for now as I don't feel confident enough. Of course it's up to everyone else what they choose to do
This message was authored by: Wheat46
Go to settings - network - press down - press green- press down to DNS - press left to delete all the numbers - press 1 - press right - 0 - right - 0 - right - 1 - press green
This worked for me, I think Annie said 1.1.1.1 is an alternative setting
I'm sky+ / talk talk and it's worked for me
Hope this helps
This message was authored by: Vanguard
Re: Unable to download programmes
I have just experienced failure with downloading the X-Files series after getting to S4 EP10 with no problems at all. Now I have noticed that the scheduler states "DOWNLOADING" but the red light is not coming on and after about a minute the message appears "Broadband connection not detected please ensure that your Broadband router is connected to a phone line".
I still have a Sky +HD box and have had a few lock-ups but relatively it has served me well for many years. I check Services page and Network tab to see that Broadband connection is OK and also connection to On-Demand is OK.
I was on the phone to Talktalk for about an hour last night and eventually gave up because they thought I had a talktalk box but it's only their router, my line has been affirmed as OK with no faults on it.
I have powered down and unplugged everything in the right order to what I have read on the internet but this has not affected the problem. I have eliminated the "wireless" connectivity by connecting the two via Ethernet cable but the same fault persists. I want to avoid a complete reset of the box as I have saved programs on here that I do not want to loose.
Any help appreciated?
Thanks.
This message was authored by: Geo24
Problems downloading programmes
Problems downloading programmes. Can't download catch up tv or film trailers etc
@Vanguard I've added your post to an existing thread, as you have the same problem. See the post marked as Answer for a workaround.
@Vanguard
If your ISP is Talk Talk then see the post marked as the answer for a possible solution.
Re: Problems downloading programmes
@Geo24
Is your broadband with TalkTalk by any chance?
This message was authored by: Llwynypia
Hi Wheat.
Thanks so much but I don't see DNS on my Network settings..
I have:
Connection to Broadband Router OK
Connection to On Demand OK
IP Address
DHCP
Network Name Talk Talk
Signal Strength
Security Type
I'm also with Talk Talk.
@Llwynypia try @oj01's post earlier in this thread for further help
I can't seem to navigate to see DNS and I have Sky + 😢
This message was authored by: Patski
When you get to Network press to go down and you'll progress from there
I've pressed to go down and then pressed the green button. I then see:
Network Name
Security
Password
DHCP
This message was authored by: BarryChall
I've got the same options
Answered - Go to Answer
