Discussion topic: Paur viewing card
Message posted on 26 Oct 2025 12:22 PM
Paur viewing card
When we cancelled multi room thr main sky box was cancelled . So we took the active viewing card and put it into out main sky box . I've paired it but to watch some programmes it wants us to pair it with rhe box .
Message posted on 26 Oct 2025 12:27 PM
Re: Paur viewing card
Since the end October 2024 Sky locked the cards to a single box, so you cannot pair a card to a different box any more
Message posted on 26 Oct 2025 12:28 PM
A Sky viewing card can only be paired to the same Sky+ / Sky+HD box that it was paired to at the end of October 2024.
Message posted on 26 Oct 2025 01:21 PM
Hi @Sharon214
Although it will mean you will loose access to the recordings on the box you used as the main one, you probably will need to swap the boxes over - as the others have said you can no longer pair cards with any boxes that they were not paired with in Oct 2024
