795
This discussion topic is read only This discussion topic has been answered Discussion topic: On demand download failure Sky+ on 2 boxes
Locked
This message was authored by: Eddy99
Re: On demand download failure Sky+ on 2 boxes
I would like to submit please - i too am getting 2 ranges when i refresh a few times
*Computer, Technology, and IT Literate*
This message was authored by: TheRealFixer
Happy to supply the IP info on request - didn't get a bubble last time though!
This message was authored by: Shut-ins
@Chloe-22
I can provide the IP address information to the community messaging team.
This message was authored by: Steve0001
I am not a tech guy. So, that said, what I still do not understand is the following:
- As instructed by Sky, I ran the NsLookup on my laptop which is connected wirelessly to my router/home network. I got two IPv4 adresses flopping around (both numbers reported to Sky).
- I ran the same NsLookup on my smartphone via the same router/browser and get the same adm.sky.com IPv4 addresses as my laptop. To be expected, I guess?
- As reported before, the Sky+ box (hardwired to the same router as above...) fails to download catch up/on demand but SkyGo via my phone (same router as above...) can download catchup content to the phone. I am assuming that the Sky+ box uses the same IPv4 addresses as my phone & laptop (?).
Can anyone more tech savvy than me explain, in simple terms (to me and no doubt many others),  why SkyGo and the Sky+ box using the same router/ISP/IP address might both perform so differently with respect to downloads from Sky servers? I understand that the answer to that question may solve the issue but I am coming from a logic angle, not a tech background.
Thanks in advance!
This message was authored by: Gavi+B
I can't say for certain @Steve0001, but I'm fairly sure that the Sky+HD box's On Demand service uses a different network protocol and/or routing to download content than the SkyGo app.
Sky Go is a streaming app where Sky+ downloads to the boxes HDD, so they use two different methods to achieve their goals
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Thanks @Gavi+B
So that sounds like some Sky+ boxes go from point A (our homes) to D (dowload servers) via 'junction' C and C is currently a problem. For the same users, SkyGo goes from A to D via 'junction' B and B is fine.
This message was authored by: MogwaiSatTV
Sky Go does stream. But for the Windows client it also allows you to download programs and to also tell your sky box to download it. The downloading onto the pc works. The sending to the sky box to download results in the same behaviour.
However it could be working as it connects to a different address than adp.sky.com or it could be that there are firewall rules or similar by the client type or app that is being used to connect to it.
This message was authored by: Lisa-P1987
We have sent invites to TheRealFixer and Shut-ins
Lisa - Sky Tech Team Expert
This message was authored by: RogerC43
We have the problem as well. Happy to be involved in providing info.
This message was authored by: Greenfingers001
Hi @RogerC43 thanks for your offer to help, an invite has been sent to chat,
This message was authored by: PocketDog
I had an chat bubble yesterday but think I saw it too late as I had no response, and now it's gone.
Feel free to add me again if needed.
@PocketDog
I have had the chat to messaging team by using the colourful bubble. I have just seen a message (top right, then envelope that I could have used .
Let's hope that after these 5 weeks of trying they will soon fix this!
This message was authored by: pn66
I have had a similar issue to those mentioned here and have now fixed it.
My situation is that I have the Google Nest WIFI mesh running in my house that sits between the various devices (the Sky+ boxes included) and the internet router.
I recently changed my broadband supplier from VIRGIN to TOOB and subsequently could not download any content from various Sky channels but could still download content from BBC | ITV etc.
If I reconnected the Virgin router it worked fine, if I connected the Sky+ boxes directly to the new TOOB router it worked fine; only connecting via the Nest mesh caused the problem.
After hours of research on the web and reading these community pages, phoning Sky and my new internet provider I finally worked out that I should put your router into "BRIDGE" mode or connect the Nest box directly to the modem (if there is a separate modem box).
Once I did this then all my Sky+ downloads worked fine.
The Google Nest hub is very clever and has overlapping functionality/routing with the new router; and I am guessing that the Sky+ downloads (for Sky channels) need some special routing/DNS/public IP setup
Anyway, hope this further information helps someone debug and fix their particular problem, good luck.
@pn66 For all of the above configurations do you in all cases just use the ISP's DNS or something else like Google DNS?
Locked
Answered - Go to Answer
